Captains chairs in bricknose
78loadstar
Forgy Ohio
Back in '93 I bought a brand new f-150 extended cab with captains chairs and console between them. Really comfortable seats. Does anyone know if similar seats would fit in my '90 f-350 with standard cab and what is involved in doing so?
Dennis
If you could find them from a regular cab or crew crab, they should bolt in.
You could make them work from a extended cab, by modifying the mount.
Dennis
OBS (93) had two different mounting systems. the bench frame is the simplest to use on a non-bucket seat floor.
usually when you find it for sale, the seller wants some serious coin for it too.
78loadstar
Forgy Ohio
Can't send pics, won't be home until Wednesday. The console is actually an arm rest that folds down from the seat back between the driver and passenger. Excuse my terminology. Friend bought this truck in '93 from original owner' I bought it from his widow after he passed away. Makes me third owner, it was set up this way when he bought it . Original owner might have changed it but it sure looks factory.
Dennis
tbirdfiend281
Eldersburg/Sykesville, MD
Ford had a lot of different things. I found an 85 EC with captain's and a center console. Not all one piece though. It was a 'Ranger' trim truck. I doubt there is any one place that even references all the different options and choices. On top of all the OEM Ford choices, there is also the coach builders that did different stuff inside the trucks, think Centurion.
chillman88
Central NY
Mine has the same kind of seats. They look factory and may have been original to the truck. I would assume places like Centurion could order without seats instead of having to get rid of thousands of seats that they replaced.
tbirdfiend281
I don't know how all that worked. Maybe, maybe not, depends on Ford really.
720Diesel
