Went to go to work this morning, 6.9 already dead in driveway with likely bent connecting rod. Get in my considerably nicer 7.3 and push my glow plugs and nothing. I have them wired manually with the ground method to a push button, my wts light flashes so I know the relay is getting the signal and I hear a click but nothing happens. I also have a led light wired to a glow plug wire in the cab and the plugs aren't getting power. I try to jump the two big terminals when I get home from work and nothing. Check voltage from yellow feed wires and it's there. So I take the relay out and confused I run a big wire from positive battery terminal to the squiggly metal post that outputs to the relay and the plugs and it sparks like the plugs are glowing.
How did jumping the two big terminals not work? I have the relay from my 6.9 sitting in the driveway but I have no idea if they're the same. I'm seriously about done with these things. Can't get one damn thing to work suddenly and **** breaking for no reason.
