Hi de ho folks, Got the news from the machine shop on Fri. In their experience the left bank (oil cooler side) is prone to cavitation.The block needs #7 bored . They will only do the work if they sleeve all the left holes & #7. That's 5 sleeved holes. They seem reluctant to even inspect for cavitation, they automatically goto sleeving. I will be into it for $4500 for machine work ,pistons, bearings, gaskets & lifters. This gives me a truck box of parts & an assemble it yourself project. Reuse camshaft, oil pump, valve covers & oil pan. Now I've gone to Ford, they have a "REMAN" engine listed . I can order thru work to get the discounts, cost $5276. Their "long block stripped" gives me a loaded short block plus front & rear covers with seals installed, oil pump & pickup, cylinder heads & valve train, & finally oil cooler. The Ford engine also comes with a " proof of dynamometer horsepower & torque supplied with each shipped engine". Sounds like they dyno the engines before making them available. The next day (Sat) I went to International. Get this I can get one of their "RENEWED" engines for $4950. It comes with all the Ford long block stripped components as well as injection nozzles, vibration damper, oil pan & valve covers. The IH parts person was unable to tell me if these engines were "run up" & had a dyno sheet provided.They will make a call on Monday to find out. Both places provide 12 month, unlimited mileage warranties. I like the price of the IH engine & the dyno sheet from Ford. Any & all comment are requested & appreciated . I want to get things on the move by the end of next week. THX Rick
