argve
Resident Fruitcake
Well she does this about 40% of the time when you shut her down. She does this after she has been running at highway speeds for a little bit but not always. She also slips when she's doing this to the point you can't hardly get the truck to move under it's own power. You can rev the snot out of her to get her to crawl. Now you can let her set and cool down and then she will work perfect (no slipping and no fluid being puked out). Seems that when she pukes she slips bad. But as said this is intermittent.
The VRV needs adjusted badly she holds her shift to the bitter end but I can make her shift if I run through the gears. I'm gonna look at vacuum lines and set the VRV tomorrow but I need to know how to adjust it. I'm planning on doing a search for that later and run down to the library tomorrow and see if they have haynes or something on it (our library has SOME manuals but not all). But if you boys want to post up a "how to adjust post" I would not complain in the least.
My thinking on the puking fluid is it might be the vent is clogged which brings up another question - Where is the vent? I'm not much of transmission guy as I haven't had the joys of rebuilding one yet - automatic that is....
Today when she did all this (slipping and puking) I checked the fluid level and it was full - actually it was a bit over full but as soon as I restarted her to check the fluid and shut her off the puking stopped. So I'm confused....
