Bumper tow?
Selahdoor
Index Wa
You could just remove it from the rear end, tape up the u-joint so it won't fall apart, and tie the driveshaft up to something if you don't want to completely remove it.
That's the plan.
Duct tape to tape it all together and a ratchet strap long enough to go from one bedrail, under the truck, and back up to the other bedrail.
Then you can tow it pretty much as far as you'd care to tow it.
I brought those things along when I brought it home, just in case it wasn't going to fit on the uhaul trailer.
BTW: For the OCD among us, of course you make sure the front end is unlocked, as well. LOL
With a little sarcasm, but also some seriousness. I'd hope that you don't have to check to know if your front end in unlocked or not. There is another option for a 4x4, you can put the transfer case in nuetral and leave the driveshaft installed. The transfer case has an oil pump that's driven off of the rear output so it still pumps oil as the rear driveshaft turns. One caveat though, it's a small possibility, but the transfer case can bounce around and put itself back into gear. The guy who owned the shop I used to work at had this happen to him one time. It was in a Chevy, it had an automatic, and it was a customer's. I have no idea how it put itself back into gear, but when it did, it took out both the transfer case and the transmission. It may have only taken out one,but the transmission was still in park. It doesn't sound possible, but I know of one time that it did happen.
Selahdoor
Index Wa
Wouldn't have to.
Would do so, because I am OCD. LOL
Oledirtypearl86
Whitehall MT
Flat towing is easy also if you make a good tow bar that will stiffen it up just get some good attachment points here is a few pics of a bar I made
chillman88
Central NY
Personally I think your BEST bet is a front hitch and tie into that, your second best option is the whole setup from your other truck.
I'm sure if you're close to the mounts you can get away with it for short distance at reasonable speeds. That being said I'm always paranoid and prefer not to take chances that are avoidable. If I was going to build one myself I would be far happier tying into the bottom of the frame rails and adding some kind of crossmember to mount the tow bar.
If this is a just in case failsafe, I'd want to eliminate the possibility of the failsafe failing. But that's just how my luck typically goes LOL
Randy Bush
Great Falls, Mt
Now that is a fine tow bar Adam made right there. got that Chevy broke to lead too. LOL
Selahdoor
Index Wa
Forget the like button, where's the love button? I love that setup!
Thank you!!
Any pics of what's underneath? And with the towbar removed?
Selahdoor
Index Wa
Yup. This is more of the kind of feedback I was hoping for. Thanks to everyone who has contributed.
I was getting the same feeling when I was considering just leaving the bumper in place, and bolting through. I don't think it's worth ruining the bumper like that. If I really absolutely CANNOT leave the driveway without a towbar, I'll probably just swap between the two trucks.
Most likely, I'll just take a chance and drive it without. .
Thewespaul
Bulverde, Texas
The obs bumper will pretzel if you try and flat tow from it. You will need to remove the bumper, and bolt on your bracket in place of it, the new bumper just can’t handle 7000 lbs like the older ones did.
Selahdoor
Index Wa
OBS. I see that all over. What is OBS?
Selahdoor
Index Wa
Ah. Yup, that's exactly what I got here. 92 Old body style. Thanks guys. And that is exactly what I was afraid of, Wes.
The_Josh_Bear
Western WA
Just so I'm hearing you right, if you have a ZF 4x4 and need to tow it you can leave both drive shafts installed? Just put Tcase in neutral and somehow it pumps through both itself and the transmission?
I find that hard to believe but then again until a few years ago I didnt even know that you'll torch a ZF by towing it even in neutral because the oil pump is off the input shaft.
Oledirtypearl86
Whitehall MT
I don have that suburban any more I took it south for my sister in law but I kept the tow bar all I did was tie into the frame where the tow hooks are located and bolted it there I used two 5/8 pins to tie to the tow bar and I pulled it 70 to 75 mph for 700 miles without a problem if you want I can take a few pick of the bar by it's self
Lance
