Built Ford Tough! Kinda...
fordf350man
Rockwood MI
if the frame isnt bent i would fix it, i had the same thing with an f250, front end was smashed and the front frame rails bent over, ended up sitting so long i scrapped it, it sat for 9 years because i had no way to straighten the frame, was a shame
Farmall Ford
Indiana
Well got a closer look...engine and everythin look fine. Took tractor and pulled bumper and panels away from tire..doesn't look too bad
Sent from my SAMSUNG-SGH-I747 using Tapatalk now Free
Oog
Southern Illinois.
What size tires? I have many good used ones youre more than welcome to have. Where in IN are you? I got friends making semi weekly trips to Evansville
Farmall Ford
Indiana
I'm way north..just south of Fort wayne. I've got some extra tires I think. Thank you for the offer! I believe everythin should b ok. Need to get front clip, grill and fender...possibly new doghouse
Farmall Ford
Indiana
Well after a tedious couple hours, I managed to pull it in the barn and start removing pieces at a time. Removed a brace for the rad, both batteries(1 has a huge hole in it :puke:) and got fender as well as splash guard out. Next to remove the radiator and such. By the looks of it my frame might be spared, will put lasers on it soon
Makes me happy to see your attempting to save it. Being inside helps too. It looks like it wil be fine with some replacement sheet metal.
Farmall Ford
Indiana
From the looks of things...the frame is fine, need new radiator, rad support, grille, inner fender, fender, headlights and hood. May need to tweak cab. Will take a while but should be do-able
tke395
