I haven't seen many of the diesel fords have manifold problems but it is very common on the small block gas ford trucks. When I bought my truck and it had the 351w in it, it developed a crack in the center of the manifold shortly after buying it. I took it off to replace it one day and it just fell in two. I was telling a friend of mine about it, who has a 97 F250 with a 351w and he wanted me to show him where it cracked, so I went out to his truck and I pointed at the spot and then noticed his was cracked too. After this I began to look at the manifolds on trucks that were sitting around and at least half of them have a broken manifold on the passenger side right in between the two middle cylinders. I know this isn't cause by just "hotrodding", the friend of mine that has the 97 is fairly old and he putts the poor truck around all them time, it is probably full of carbon, and he bought it new in 97.
On my truck when it had the crack you would only faintly hear it when idling and cold, once the truck got up to temp the crack would close and you wouldn't even know it was there.
