Time for another update. Truck did fine the rest of my trip and all the way back to Virginia. Seems the AC was feeling a bit weak towards the end of the trip but with it being 95 outside I figured I probably just needed to clean out the evaporator box as I'm sure it's got junk in there.
2 days after getting home fro Florida I flew to Seattle and then went on a cruise to Alaska and didn't even start the truck again until last Saturday. So 18 days later therexs no AC. Check system pressure and it's at 25 lbs total. Yep got a leak, again.
Since I had replaced the compressor and dryer and seriously cleaned the lines, evaporator and condenser I decided to get some dye and see where the leak is.
So I recharged the system with the dye and have been running the AC on max the last couple days but nothings visible yet. It's a slow leak apparently.
In other news I installed these earlier today.
Not road tested yet but I'll be driving another 75 miles before getting home tonight so they'll be checked out today. Hoping for a miracle but not expecting one.
The old shocks when compressed off the truck just stayed that way. They were done.
And lastly my tach sensor has started acting up. Standard intermittent ooerating problem so that's next apparently. Looked at the wires and they're pretty bad so no surprise there.
