IDIDieselJohn
0-60....eventually
Well fellas, I finally found a good parts truck to restore mine. Only thing i'm missing now is a 8ft. dual tank box. But I got the most important for now, the cab. The truck I bought for 500$ is a 1990 Ford F150 shortbed special "Nite" edition, been repainted silver. No engine or transmission in it, originally had a 351 with a 5 speed. Has new doors, fenders, tailgate and hood. Only needs driver side rocker. (will replace both sides)
Major resto plans:
Strip everything from the frame.
Sand blast and re-paint the frame, and axles.
Swap the cab, body parts and floor hump.
I won't get into the details now, but I do have a few questions and I'd like to get some thaughts on them.
1st, frame will be sand blasted and re-painted black. But also I want to "truck bed coat" the whole frame so it never rusts again. Hows that sound to you guys??
2nd, I want to "truck bed coat" everywhere under the body, (under the cab, box, fuel tanks etc.) does that sound like a good idea?
3rd, now this may sound abit weird, but here goes. I know my 7.3 has over 568,000km (376,000 miles) but I don't want to touch it! I'll give it a full tune up (8 glow plugs, injectors, maybe IP etc.) but no rebuilt nothing of that. I do want to take out 2 pistons (#1 and #8) to look at them see what they look like, rings, bores, pistons and bearings. If all is good I'd like to leave it as it is, just change all gaskets and seals. Does that sound like a good plan, or should I look for something else or do something else?
The big challenge of this is i'm trying to keep the truck as original as I can!
Thanks for reading guys! apriciate it.
P.S
restoration will start anytime this winter only if we can find a shop to do it in, if not, we'll do it right in our driveway in spring. But i'm sure we'll find a shop.
Major resto plans:
P.S
