Baby Moose Pump
Probably as a result of Ray's glowing review, I've been getting more requests for pumps like what I did for him, which is just a high quality stock spec pump rebuild. Since there seems to be a good bit of interest in this, I figure I should give that pump a name, and since Ray already used it, I'll go with it. This would be known as a Baby Moose Pump. I've amended my original add for the Moose Pump in the Marketplace to include this version. So individuals interested in avoiding the problems Ray had with unreliable third parties can have a reliable alternative on the board.
Moose Pump add in the Marketplace
HammerDown
Glenolden Pa
Yea ok, if you say so but...my "Baby Moose Pump" gave my 7.3 some nice perky Moose Balls and a hairy chest!
Thanks for using the name Mel, ;Sweet
Guys, most of the time my life is full of things 'I should have done'...for a fact, I should have sent Mel my IP months ago!
EMD_DRIVER
Say what?!?!
Beaufort, SC
I asked Mel about doing a standard rebuild several months ago, and here's his reply...
"A standard rebuild is not much cheaper than a Moose Pump. It takes about the same amount of work to do both, and only a difference in cost of around $50. It depends on the condition of the pump, but prices have been averaging $550 to $650. - Mel"
Diesel JD
Gainesville, FL
However a high quality stock rebuild is probably more useful for the members without a turbo since all that extra fuel delivery will just be smoke for a NA engine.
HammerDown
Glenolden Pa
exactly...no turbo here but now it sure feels like my engine is on some type of steroids! ;Sweet
Hey Mel ...:hail :love: ..............:yell:BABY MOOSE PUMP!
:cheers:
A fresh IP and injectors with a good timing job makes a world of difference.
zukinut
bristol tn
Not to hijack the thread but what do you mean by good timing job. I have the meter and the tools and a good amount of knowledge. Is there a calibration machine that sets it dead on like a dwell machine does on a gasser. Or do you just pick the timing you want to run, set it there, drive it.
Thanks again
Will
Well by a good timing job, I mean using the right tools and knowing how to use them. A lot of guys have paid for a timing job only to find later that it was set by ear, and by the time I look at it is is no where near close.
