jgroover9
Hey all,
This is my first post but I have been reading this form for a year now. Appreciate all of your help on different topics.
I have an 86 F250 6.9 C6 Auto 4x4 stock no turbo. Injection pump went out a couple months ago, and I just removed the pump and injectors. Am going to send them to be rebuilt by Moose Diesel. A couple things I noticed when removing...
1) One of the nipples on the RVR is snapped in half - the snapped off half is stuck in the vacuum fitting.
2) The red plastic on the accelerator cable cracked to pieces when I was removing it.
My transmission was already shifting pretty rough (late shifts, and extremely hard when it does) but it was driveable with no issues. A couple questions.. Is there an easy fix for the RVR without finding a new one? I saw there is a new mechanical version sold by Accurate Diesel, but after talking to him it sounds like it won't fit without pulling the transfer case out/cutting into the crossmember. Plus at that price point, its almost worth doing a T19 swap.
Would it be worth it to just swap to a T-19? What would yall look for when inspecting a used one off Facebook Marketplace? Theres a used one of a 6.9 for sale with the flywheel, crossmember, and transfer case for ~400 near me. I've looked for diesel ZF-5s but they are hard to come by in southeast Texas. Budget is a little tight since I am already getting a new IP and redoing the fuel system (planning to add an electric lift pump, put a new water separator on it, either clean or buy new tanks, and redo the supply/return lines from the tank).
Additionally, do y'all have a good recommendation for an accelerator cable replacement? A couple pictures attached.
Goal for this truck is to be able to tow my car when I have to move around January. Look forward to hearing from yall!
Josh
Josh
