gonecrazyi
As most of you know I spun the yoke on the rear pinion last week.
Well I went and pulled another axle today out of a 96 f250 crewcab that has an axle code of c5, which I think is 4.10 with limited slip.
The axle code in the door of my truck reads 35, what would this code be?
The only thing that I have to pull on the other truck are the mounts for the sway bar thats on the new axle. Do you guys really think that I need this, if not that would save me from having to torch the rivots off of the other truck.
Also there is a sway bar on the front axle of the other truck, would it be worth pulling it to put on my truck?
Thanks in advance.
Thanks in advance.
