gandalf
Senior Member
Over the weekend I finally got tired of having the three auxiliary gauges (pyro, trans temp, water temp) as daytime gauges. I wanted to see them at night too. I had never bothered to wire in the light power. So Thanksgiving morning I tore the dashboard apart enough to pull the headlight switch to wire in the aux gauges.
I found a wire which dimmed my test light as I turned the knob to dim the guage cluster, and I said, "Thats the one." I can't remember now what color it is, but I know it has a stripe. I connected a lead from each guage bulb to the power source, and the other lead from each guage bulb to ground, and put it all back together. I never thought to test further.
Things aren't quite normal. The aux guage lights come on as soon as the engine starts, whether the headlights are on or not. They are not on if the engine is not running. When the headlights are on they function as they should--they dim with the rest of the guage cluster lights when I twist the headlight knob.
I think I must have found the right wire, because the aux guage lights dim when they should. But why do they come on at engine startup? Is the ground perhaps supposed to run back through the switch? Thats about the best explaination I can think of.
Any opinions or answers?
