I scored this pretty cool 60 gal diesel tank off a military 6X6 truck and I would like to install it in the bed for long trips but I have few questions. It has 3/8" fuel supply fitting a 5/16" vent fitting and a single pole sending unit.I would like to tap the fuel lines and use manual switch over valves but I am unsure of the venting and proper routing to insure correct operation, what valves to use and a good place to get the parts. Will it mess with the electric switching valve tapping into the fuel lines for the auxiliary tank. Any ideas or help would be greatly appreciated.
The electric valve will soon fail anyway; so, now would be a good time to get TWO WeatherHead brand FOUR-WAY manual valves, one for DRAW and one for RETURN.
I doubt that 5/16 fitting you mentioned is a vent; more likely it is for a return-line.
Without actually having the tank to look at, it is hard to say for certain; but, any vent should be at least 1/2".
No special plumbing is required for a vent, so long as it's top end is located such that water is unlikely to enter the tank.
Not totally necessary, but I do TEE all three of my tank vent hoses together into one main open-ended vent located high and dry.
Should I forget to switch the RETURN valve to the proper tank and thus over-fill a tank, the excess will go into the vent lines and gravity feed into whatever tank has room for it, preventing the fuel getting pumped out on the ground.
I located my manual valves alongside the outside of the frame-rail, with the operating stems protuding through holes drilled through the floor.
The stems/handles are on the side of the "seat hump" on the driver-side, between the seat and door, easily accessible from the driver-seat without having to reach.
You will have to use hose-barbs and splice a foot or so of flexible rubber line to each of the plastic lines at the electric valve, then connect them to the manual valves.
I do not trust that business of tapping a big auxillary tank into the vent or filler-tube of a factory tank;sooner or later disaster is imminent.
