ATS turbo
knightlogger
US
How can I make my ATS 088 better it has some lag and I was to have it spool quicker and at a lower rpm. Would putting a cone filter on a 45 degree bent tube be better than the air box ? Thanks for the tips.
Sent from my XT1585 using Tapatalk
Clb
Another old truck
nannyfornia
Do some reading, type4 or agnem are your builders
knightlogger
US
Ok because I was told to try a wicked wheel.
83ford
ford diesel baby
calico rock.arkansas.us
Wicked wheel won't work on an 088 will it? It's just the 093's I thought and like they said talk to one of them guys they'll set you up
Sent from my Iphone using Tapatalk
HS108
Diesel Newb
Connecticut
Talk to Russ (typ4) The wicked wheel II is for the 093 turbo only.
Russ can make that 088 turbo sing, his mod is to make more boost at lower RPM.
If only I had the $$$$$ :(
Waystro
No Class
South Texas
Oh my apologies I thought the ww2 worked with the older turbos
Thanks for clearing it up guys.
Russ can work magic on the 088 kit.
but the fact remains, its still a non gated kit.
if you want quicker spool ups, find a 093 kit.
then you can get the billet wheel.
knightlogger
US
Would I have to take my turbo out in order to have the mods done or is it something I can do ?
Black dawg
sw mt
Wrap the up pipes and first couple feet of down pipe, and buy or make a turbo blanket to cover that exhaust housing. The difference will be noticeable.
also set timing at 6 deg instead of 8.5. How far is you fuel turned up? Usually takes atleast 2 flats.
knightlogger
US
I'm really not sure but I want to say it's cranked because I role cole more than I want to. Also it's lagging like I have to much fuel. I also don't drive with my foot heavy to the mat
I do have a billet wheel available for the 088. its a bit more than the 088 mod I normally do.
mbarry98
Sycamore,il,us
Also interested in the possible mods I have an 88 that does decent on the top end but I need to time it.
