ATS 093 hat o-ring part#
snaponprofile
NY
Hey guys, I need the part number to the 093 intake hat oring.
thanks.
6 Nebraska IDIs
Which one? I have them all in Caterpillar part numbers but which one are u looking for. There are two orings for the intake hat.
Goose_ss4
ca
i gave up on trying to get that oring to seal. every time i would stand on the thing the boost would just blow it off, and then i would just blow out. i call it an oring because it is thick like and oring, and not flat like a gasket. if that is what you are doing. i simply siliconed the **** out of the manifold mounting serfice, and let it seal up real nice. then i had a guy tig weld a 3" 90° elbow, aluminum, to clear my piping for my intercooler. hasnt leaked yet.
snaponprofile
NY
I want to try to get the right oring - I might resort to RTV if it doesn't work though.
rhkcommander
Oregon
Theres one that goes from the hat: 5.25" roughly but im just guessing (size of a cd/dvd), use a carborator gasket oring deal
the one that goes INTO the turbo is a 2" oring inner diameter. That much i know for sure. I got one sitting on my desk and it was a #$%#%$ to find. Ill try to find the invoice I had but it was a small website who ordered it from ATS so you might just give them a call :dunno Looks about 3/8" thick but I'm eyeballing it. When I feel better I'll try and find some calipers for accurate measurements
reklund
Henderson, Nevada
Cross reference it to McMaster-Carr catalog. Order a square cut o-ring in the correct diameter, whatever thickness you want.
I warped my ATS Intake hat welding on it for my setup, and ordered a 1/4" thick o-ring to take up the warpage. Haven't had it leak yet. Silicone is not intended to take pressure without constant force of 2 pieces holding it in place. Filling that sort of gap with silicone is asking for trouble eventually. I know it works short term, but it's just not designed for that application, plus it's a pain in the ass to take apart and reseal later if you have to service the vehicle.
Get a good viton O-ring and never look back- you'll be glad you did!
Ryan
Goose_ss4
ca
I have had it on here for two years, and drove across country with it. no problems
greg_a_morton
blossom tx
will this one work on my ats 088 kit? I have yet to get over 6-7lbs boost and I think it is in my hat oring to turbo!
rhkcommander
Oregon
99% sure. I got the intake snail separate but it looks like the one in the diagram so it should lol.
snaponprofile
NY
I'm looking for the the intake manifold to turbo hat o-ring anyone know if nebraska has the part #??
tke395
