"O-Ring" or "Seal" for injection Pump Adapter Cover?
OkieDieselMan
Oklahoma
Having trouble finding the correct "Seal" or "O-Ring" for the Injection Pump Adapter Housing "2-Bolt Cover" for my 1993 F250 7.3 non-turbo IDI Engine.
Does anyone know the Motorcraft # and or a place to buy this Part?
gandalf
Senior Member
CA &/or Maine
Its been a very long time since I've had that cover plate open, so my memory is a bit fuzzy, but I honestly don't remember a seal or an o-ring there. My recollection is that I simply squeezed some gasket maker goo around the opening and set the cover in place and tightened it down. I could be mistaken in that memory, in which case somebody will correct me.
When I have replaced the cover plate, clean it off good and applied some RTV gasket sealer.
I replaced the IP year ago last Aug, and the guy that was in there before me used RTV.
There was just sealer there from the factory. No seal, no o ring. I also use RTV.
sramasya
