For the past month, my return caps have been leaking pretty bad and getting worse...
I'm leaving puddles of fuel under the engine and now the stuff drips from all over the undersides of the truck when I park!
It's really bad... And the smell of raw fuel while driving is strong! That's how bad it leaks...
I've already replaced the return caps two weeks ago and checked the IP for leaks...
Some of the caps started leaking shortly after I installed them. I know that I did them right, they didn't leak for a few days before they started their **** again... I installed the previous caps when I installed the engine and they lasted about two years without leaking...
Do any of you guys think that maybe the source of my troubles might be due to a bad FSV (Fuel Selector Valve) blocking the return line back to the tanks?
Wouldn't that cause the returns to pressurize and blow the caps? Just thinking here...
I haven't been able to use the front tank because of the FSV and wondered if it could block the returns to the tank I've been stuck on?
I'm thinking about taking it apart and cleaning it, but wish I knew what size bolts to use to put it back together and should I buy some gasket sheets?
Thanks guys, I appreciate all of the help you can give me...
