Anyone got an 'Ag' governor?
Macrobb
North Idaho
Pretty much what it says in the title. Apparently DB2 pumps can come in agricultural/industrial as well as the common road-governor style; I'm planning on putting an IDI in a piece of equipment, and want to buy a constant-rpm governor assembly to try to mod into a stock DB2 IDI IP.
What is the pump calibration number you are trying to replicate? There’s many different AG governors for these pumps, some require different housings some do not.
Macrobb
North Idaho
I'm not sure. I'm trying to take a standard 6.9 or 7.3 IDI pump and make it more or less 'constant-rpm' for use in a Bobcat M970.
This application should need about a ~85HP engine; but an IDI is thousands cheaper than the correct motor, gas OR diesel.
zemmeron
