Anyone driving a truck with an IDI on long trips?
VanGo
Michigan
Wanted to see if anyone is using an older vehicle with a IDI for any extensive travel?
If so what spare parts do you generally keep packed “just in case”?
Thanks
I exclusively use my idi as my toy hauler. I go camping at least once a month. All I keep is a small hammer, a quarter inch ratchet set from 5mm to 14 (standard equivalent) and some spare fuel return caps and fuel lines. Bag of zip ties and side cutters. Literally never need anything else.
DirtyWood
Earth
I always keep a spare set of belts, return line components, plastic & metal zip ties, fuel filter, 5/8" heater hose connector, and a 3/8" ratchet set. So far I haven't needed any of it.
Clb
Another old truck
nannyfornia
To actually address your question...
I do carry a full set of repair tools less specialized stuff, a serp belt vac pump for ac. Fuses ect. But if I was in an old high mile rig I would carry items that I would be able to replace in the feild rather than call a wrecker...
I carry a bit more in the rockcrawler but don't drive like an idiot so I can drive it home..
rreegg
IDI n TDI
Puget Sound
these are interesting threads because different trucks have different weaknesses and need different extras
I mostly travel hwy 5 and have done seattle area to San Diego a few times with other trips to central Cali.
For a long enough trip oil change supplies and try to keep tire change items on hand, like bottle jack and breaker bar. Otherwise just maybe a small socket set and spare fuses.
Really want to spend more time in Utah and Colorado but the 4.10 gears get painful on the freeway…
These are more day to day but I also try to keep consumables on hand like gloves, paper towels, funnel, oil, fuel additive, basic strap wrench etc
Black dawg
sw mt
When truck was still an auto, had a starter behind the seat.
Before I converted to 3g alt, carried a spare alt and regulator behind the seat. Never actually swapped one on the road, but but could have twice. Both times was within an hour or 2 of home and made it.
Belts.....
Vacuum pump....was another problamatic one for me.
Really didnt have that much trouble all the years of driving these trucks, but always checked over pretty well between trips.
If I had a serpentine belt setup, I would figure out some way to bypass or run a shorter belt in case the A/C pulley goes bad. I have seen that stop one of these trucks in it's tracks. The serpentine belt is superior to v-belts, but you have options when things go wrong with the v-belt setup. Even though you may not use the A/C, it has a bearing inside the pulley that turns all the time. I see some of you carry a spare vacuum pump and alternator, I guess that would take care of those. You still have the power steering pump and the waterpump, but they usually give signs before they crap out altogether.
Clb
Another old truck
nannyfornia
Non ac trucks use a different belt and possibly " don't quote me on it " a different tensioner routing iirc....
So one should be able to carry the backup belt and reroute it...
hidyusa
NE
1986 F250 6.9L - Doing a 7.3L swap right now in my '86 that I have had since '93. 6.9 was still running but my boy and I turned it into a project. Was my farm truck, now it is in the city, used mainly for hunting. 300K plus in this truck and it has never left me on the side of the road, was my daily driver up to about 10 years ago. Many trips from NE to TX without 1 problem. I have a toolbox on her so I keep a basic tool kit. Belts hoses, just your normal maintenance items. Starting fluid in case of glow plug problems. Jack handle works to unstick the front calipers as that happen to me. I am going to put on the V belt system back on the 7.3 as it has proved to be bullet proof. I have towed many serpentine trucks with this pickup because of A/C problems. Complete bullet proof when looking at today's stuff.
89Laredo
Underemployed
Not Canada
85 250/c6 Did 2 900 mile trips, no problems.
83 250/t19 did multiple 700 mile trips. Lost a rod bearing one time, multiple broken injector lines, intermittent tail lights, brake wedges liked to pop out.
In all of my vehicles on a long trip I keep a full tool kit including wiring, multimeter, sockets, wrenches, prybars, jacks, belts, jump pack, any vehicle specific parts (spark plugs and coil packs in the car, injector lines, fuel hoses, and filters in the truck), fire extinguisher and a high vis vest.
FrozenMerc
SW Missouri
My wife and I live in SW Missouri, most of our extend family lives in the Northern half of Minnesota or Eastern North Dakota, so we routinely make that 700 to 900 mile (one-way) trip, and if we have to haul anything, the '85 is normally tasked with the job. It has made the run up and down I-29 and I-35 dozens of times, and knows the route well. I rarely carry anything besides a full tool kit, extra fuel filter, and some basic electrical parts like light bulbs and fuses. In the winter we will carry a winter survival kit and anti-gel as well.
