Anybody have any junk PowerStroke valve cover gaskets?
jhenegh
Truck Still Earns its Keep
Deerfield, WI
I discovered by accident/chance that the bullet connectors used on the 7.3 Powerstroke valve cover gasket/glow plug harness are really good, and have 2-4" of wire on them, so they work great to repair IDI glow plug harnesses.
SO... anybody have any junk valve cover harnesses laying around? I find myself in need of 8 good female bullets and I can't find those particular female ends anywhere but in those Powerstroke harnesses.
Thanks
jhenegh
Deerfield, WI
Well I’ve got some used 7.3 powerstroke ends on a harness I made going on 2 years now on with 0 issues.
I tried the 6.0 harness before and they didn’t stay tight enough, particularly around that one bolt casting in the intake manifold. I’d always find one loose every time I checked.
Every other crimp-on bullet receptacle I’ve seen without plastic molded around it has a seam in the metal which always loosens up after a few months.
Macrobb
North Idaho
I wouldn't mess with the powerstroke connectors.
they get deep fried with every cycle.
old PSD harnesses will have brittle insulation and not really worth reusing.
I will say that of the 3 7.3 PSDs I've taken apart('00 at 230K, '02 at 385K and a '97 at 499K miles respectively), the harnesses looked just fine... Not brittle, totally reusable(and I did on two of those three). I keep hearing that they get fried etc... but I sure haven't seen it.
ive had 2 sets that were brittle as hell, and cracked when I bent it.
jhenegh
Deerfield, WI
I got my hands on one gasket from a friend who had a parts engine.
I tell you, those ends just fit REALLY WELL onto glow plugs. Wish I had found 8 but at least one half of the harness I was fixing has good ends now.
If you have a 'stroke harness and the wires aren't brittle, save the glow plug ends off it for an IDI harness!
dgr
sac town
Did you post down one forum? PSD guys might have PSD VC gaskets
tke395
