Any good deals on transmission jacks?
jwalterus
Made in America
Air Force
Garrison, ND
I've got the HF scissor style one as well, mines a little older (try 20 years LOL)
have pulled t-19s, zf-5s, and c-6s with the t-case on them, I just stick a board on the floor jack and use it for under the t-case, tie them together with a ratchet strap, lower the whole setup and pull straight towards the rear with the jack handle ;Sweet
dunk
Dunce
NJ
Curious about this. I've done them solo before with a regular floor jack and precarious balancing, have done C4s solo by hand, or just muscle them up and get the crossmember slid in place if you have a helper. Not sure I'm up to all that anymore so a good functional trans jack might be the way to go. How do the different cradle designs work on manual transmissions? Most seem to be made to fit the pan on an auto, not necessarily stable with round or odd shaped manual trans bottoms?
Mine is some old used and abused unit. Works absolutely fine for the zf.
If you don't use the chains, I run a couple ratchet straps around to secure it.
DirtRoads
United States
I pulled the carpet and front seat, removed the panel in the floor and stuck my engine hoist in the door for a clutch change on my 92 with a ZF-5. Just something to consider, it worked great.
laserjock
Almost there...
Here is my version for when you need a little extra lift.
ironworker40
NYC Ironworker
nj
You can also pull seat and floor pan, with the windows down put a 4x4 across doors and use a chain fall or come along to lower it down.
texcl
W. of Cavalier, ND
Alright, I ended up getting the scissor lift from HF. There are lots of reports of it working great on zf-5's. My transfer case has a leaky seal anyway so needed to pull it. It ended up being $79 with my 20% off coupon and you can use it to support doors when changing pins out or even put a chair on it to lift you up, lol. Anyway, we are still cleaning the shop real well before we start, will take pics and report once we begin the big jobs (d50 ball joint replacement and front right drive shaft R&R + SMF/clutch conversion).
laserjock
Almost there...
I actually used mine for door alignment as well. A pool noodle cut in half does a real good job of laying in the V of the jack and giving it some cushion.
subway
be nice to the admin :D
York PA
One way to do it lol, I could not get my heavy transmission on my jack after I dragged it under my truck.
N/A idi do it from the top with ratchet or wrench.
Long extension and a knuckle will work. Just make sure to at least break loose/tighten from top with a wrench.
laserjock
Almost there...
3/4" ratchet wrench works good once you break them loose from above.
