Does the way this previous owner hooked up the boost gauge work?
headhunter38
California
The red highlighted line is connected to the boost gauge that the previous owner installed. Is this a viable way to do it? Im not getting any movement on the gauge. I have read about the circled in blue pipe plug on the intake snail. Should I switch it to that spot? 1994 factory turbo f350.
Clb
Another old truck
nannyfornia
Pretty much the same, ugly? Perhaps.
The gauge is suspect, try feeding it regulated psi, 5-10psi observe the gauge.
They tapped it into the wastegate line. Yes it would work, but yeah, ugly. I put mine on the port you highlighted blue. Sounds like your gauge is a dud
headhunter38
California
Ok so i think the guage is good. I haven't had a chance to do what @Clb suggested yet. I will do that soon. I noticed the hose to the waste gate and metal line were all really loose. I removed the ugly t fitting and put in a new rubber hose with good constant tension clamps and new fittings into the turbo. I also relocated the boost gauge fitting the intake snail. Now I've got some movement on my boost gauge. Not even one psi but Its moving now when it wasn't. So i think I have boost leaks. I did see A LOT of soot around the manifold to the downpipe slip fitting.
Clb
Another old truck
nannyfornia
Fix boost leaks, I bet that fixes the gauge.
Fwiw
My 093 had the wastegate set at #3 psi.
Why? I dunno!
So it doesn't need much to kill the movement at that psi.
Now making #15, you might loose a few psi...
Black dawg
sw mt
I would test the gauge first before looking for big leaks. These turbos make boost pretty easily, even with some small leaks. Make sure the wastegate is held closed.
