spent a bit out there now, the grinder i got wont fit up there, I tried vice grips, shimming it, hammering it, bending it, you name it, not gonna happen. At this point i'm really out of ideas. There isn't enough space to grab anything from the engine bay side, and heaven knows theres no room to work from under the dash either. Might have to throw the towel in on this one as dumb as it sounds. I just can't think of anything else that would work. Hell i even broke a screw driver trying to break the MC by prying against the firewall.
Ok so your in this to win this for sure NOW....
Start by accepting that the MC is NOW going to DIE a slow death, you will now purchase a NEW one!
Remove the Brake booster from firewall....pull away carefully and get yourself clearance for working on the clutch MC.
With Bracke Booster out of the way, you have lots of room for surgery.
Now however you can...remove as much fluid from MC..Turkey baster comes to mind...and some toilet paper to get finial little bit out.
Once MC is as clear of fluid as possible, you can probably NOW cut the MC off the firewall...I'd start by cutting JUST behind the reservoir leaving a small stub sticking out so no reservoir just the MC tube and two mount tabs...
BE EXTREMELY CAREFUL NOT TO DAMAGE TUBE FROM MC TO SLAVE!!!! Just sayin...BE CAREFULL!!!!
Now with the MC reservoir out of the way, you can proceed to cut/hack grab bend do what ever you need to to get that stupid spinning stud stopped or cut/ground away and the rest falls into the cab!
I hope this makes sense, it sure does in my head!
DON"T CUT THE PLATE...you don't need to.
Just absolve yourself to replacing that MC and your golden...if you can afford it get a new slave too....in for penny in for pound...do this one time...not two ...
Try to get the metal MC and slave with a good proper bleeder screw!
IMHO if your installing a new MC do the slave at the same time and know for certain both are new, and you won't have to worry about them for long time! If you are lucky, there maybe a pre-bled setup for you!
JM2CW
Al
BTW Good luck...and TAKE LOTS OF PICS! PLEASE
