John Ennis
Iv'e had my truck for about a year now, just about to break 300k miles. 1993 7.3 iDi non-turbo with a 5 spd. Anyways, when I bought the truck the guy said that if you go to the front tank, it will run for a little bit, then start sucking air. I took his word for it and I only run out of the back tank. I've looked at a few parts that it could be, but do any of you have any thoughts on what it might be? My plan is to drop the tank, clean it out, change everything in it and any flex lines installed. I know that the tank selector valve was working fine, but I havent used it since I bought it. I've changed all the flex lines on top on the motor, from the pump up. Any ideas? Thanks in advance.
