after ip install...no A/C
RockinB
SWFL
So, ip install went OK, only now I've got no A/C. I did move the hose and line that are against the firewall to get enough clearance to R/R the ip assembly. I don't see any leaks anywhere. Any ideas?
Thanks,
Bill
Sounds like you wiggled something that you shouldn't have. Old rubber doesn't like to be disturbed. If your compressor is spinning, undoubtably you've let the cat out of the bag as it were.
Dsl_Dog_Treat
Decatur,MI
check the electrical connections on the compressor to see if it's getting told to turn on.
+1 on that.
Since that connector is in the IP harness, that would be my first guess as well.
RockinB
SWFL
Clutch does NOT engage. Connections are on, I just reseated them. I guess I need a VOM to test for voltage out of the connectors. I did verify the fuse was good.
That's good news. That's a much easier problem to correct. Check the fuse.
