idi_Marty
I am selling a 94 crew cab, dually 4x4, it's a cab and chassis conversion, the frame rails are approx 34" apart. The reason I'm selling is that I'm buying another truck, I have put a new injection pump, reman bb code injectors, new glow plugs, I put new bushings, new 270 degree thrust, and a step gap piston ring in the turbo, and a new compressor wheel, more or less I overhauled the turbo. The truck does not have a tailgate, and the fenders have the typical rust above the wheel wells. It has a e4od transmission. Truck keeps leaking oil at the turbo drain (not the valley pan) or around the cdr hole on the valve gasket, and the tach quit working the other day. I'm stumped, so I'm selling it and moving to a newer truck. $2500 firm, located at zip code 41189.
1994 Crew Cab F-350, 7.3L idi Turbo Diesel, 4x4, auto, DRW, Tollesboro, Ky
