91 7.3 siezed after sitting for 2 hours?
Idilarry89
Hot springs sd
Sorry I thought I posted a pic the valve is completely dropped out of the head
G. Mann
Phoenix, AZ
Picture did not post. Likely because you didn't use the "Go Advanced" posting feature ...
Please try it again..
Idilarry89
Hot springs sd
Hopefully that worked...sorry I'm doing this off of my phone as it's my only life line out of my little town :rolleyes:
G. Mann
Phoenix, AZ
Thanks ! ... Whatever you did this time worked.. good clear pic came up..
Ouch.. looks like the valve spring even went somewhere, along with the retainer and spring cup..
Carnage shots as you take it apart please.. we feel your pain more that way.. hahah
From the truck pics, not a bad looking truck.. certainly worth the purchase price.. good find..
Fix the engine, fix the brakes, and drive it like you stole it.. for the next 10 years.
larson
Springtown,texas
That looks like some good oil sludge/carbon looking build up on the rockers and such. Don't recall to many other users pics with valve covers removed with that kind of poo poo all over the rockers.
With that being said it could be nothing.
Hmmm...mee sees a setta heads in order....thats clearly soot from bypass valve guide like my post mortem video ...guess yer lucky maybe...
Hydro-idi
Lodi, California
Very sorry to hear about these findings. But this is a great example of what happens when you have a worn valve guide that goes ignored. First symptoms include ticking and/or chuffing from exhaust. Next, valve burns itself up & does not seal properly against seat, which is crucial to proper valve dissipation of heat. Next is what happens here. Valve face starts to crack and fall apart, retainers pop out & valve drops into cylinder & eats $hit up. Excessive guide wear also lets combustion gases into the valve train area, which is why you see all that carbon gunk.
Curious to see what's behind that cylinder head. Seeing this kind of damage, I would be pulling that engine out and see what you got to work with. Hold your chin up tho, lots of members here to help you out!
Well from the sounds of what you say happened... I'm not thinking you have a ruined cylinder but.. Only opening the engine will tell you what and where the damage is that keeps the engine from turning. If a piece of the valve broke off with the piston nearly at top dead center you may just have a mark in the piston but might be able to run it with a valve job. Some owners get lucky and some don't..
Idilarry89
Hot springs sd
Well yeah. It does sucks but on the bright side it's not a cavitated block, and the engine still turns. The engine is definitely coming out. My goal is to have it back together or the engine out of my 89 stuffed in by the 7th so I can take it to my buddy's wedding which is only about 150 miles away. Pics to come. I'm going to stop at the truck stop and use the WiFi so I don't eat up data....also oil burners runs REALLY slow on my phone...now, time to dig in a little farther. got her in the shop!
Idilarry89
Hot springs sd
So no carnage pics yetc. But engine is out and I found the suspect valve head in the turbo cross over pipe
CLICK ADVANCED WHEN ADDING PICS.....
Ok I canna waita seea thisa broken pisa machine
Idilarry89
Hot springs sd
I'm doing this from my phone and it really sucks adding pics...it's SOOOOOO slow and this is the only site that is this slow and I don't know why :mad: ...hopefully that worked
Now, I'm no mechanic, but...I don't think that I'm supposed to find a valve head in my exhaust piping... :dunno
FarmerFrank
Blairsville, Pa
Sounds like your more of a mechanic than some of the mechanics I work with
Idilarry89
Hot springs sd
Haha I was being a little sarcastic. I grew up in a professional shop, we worked on anything that ran even though we were a glastron boat dealer, and a marine shop.I now own the local small engine shop, and I do automotive stuff when I'm slow.
taylerperson
