Guffey6
Hey guys, I have a 1988 f250 idi non turbo zf5. 3 weeks ago I changed my injector pump with a used one off of a parts truck I bought (mine stopped pumping), and it ran so much better than it ever has. Last weekend I changed all fluids including rear diff and I changed out the valve cover gaskets ( looked very clean to my surprise)
So I decide to take it on a road trip( I travel for my job) a 300 mile round trip. The truck ran wonderfully the entire way down and 3/4 of the way back until... highway speeds it would almost act like I was running out of fuel every so often. Then, As i was stopped at a stop sign as I started to go it acted as if I were pulling a load starting out in 4th gear. (Not good). Very low power and sounded rough until it got up to around 40-45mph where it acted fine but with a lack of throttle. It barely made it up the mountain on which I live. Thankfully I got it home.
The whole time I'm thinking injector/ pump/ clutch slippage. I crack all injectors at idle and all 8 made the engine shutter. I also checked the schrader valve and my reading is 4psi with a tire gauge. Hopefully it's just a bad lift pump, considering I'm doing the facet pump mod soon, but if it's catastrophic I don't want to waste money.
Oil looks good
Coolant looks good
Plenty of fuel in tanks(fresh)
Been running power service in both tanks and in my filter
New wix fuel filter
Ps: while it's acting up under load, I'm getting greyish smoke. And It acts like I'm running out of fuel with the surge and stall.
Sorry if it's hard to read, I'm not a writer by no means. Please help!
Oil looks good
Coolant looks good
New wix fuel filter
