gotta have it 1 color.
today i welded in a piece of 2.5 box tubing on a cross member for my wishbone.
ran it so hot a ****** berry found its way into the threaded bung for the johnny joint.
had to order a 1"-14 tap
made a plate for fuel pump and regulator.
welded it to the frame.
need to buy a battery, but the 4D/8D batteries i can get local, are all top post.
no thank you.
i want studs for my cables.
once i get the battery, i can weld a tray together and get it in.
not much left to do on the list before the chassis and underneath gets preped and painted..
may use Laserjock's bedliner for underneath the body, or i may just POR 15 it...
first things first.
to get the truck 5' in the air, and remove axles.
then steam clean.
gathered steel pipe 3" and 6" to make saw horses.
re-strip and then start painting little things too.
bell housing on its way for the engine run stand,
thats next weeks project.
i have batteries, extra radiator, fuel pump, gauges, and all of the relevant material...
maybe get the engine fired up and ready to install
