Hi everyone, I just bought my first idi last week. It's got the newer gen sidewinder on it. After it sat in my driveway for about a week I noticed some oil leak coming from what looked to be either the rear main seal and the oil pan as well as maybe the little drain tube between the transmission belhousing and engine. I degreased and washed the whole engine bay and undercarriage today to try to pin point the leaks better. After washing it and letting it dry I took it for a drive and when I got back I looked underneath and saw small oil droplets dripping from that drain tube area as well as some coming down the passenger side of the oil pan and rear main area. I popped the hood and noticed seepage around where the intake hat mounts on the manifold. I had my cousin look at it while I revved it up and put it under a couple lbs of boost and he instantly said he could see oil bubbling out of where the hat seals on the intake. Is it normal for oil to be in there and maybe the intake hat seal is bad? Or could it be a leaky turbo seal or bad cdr valve?
I'm fairly new to these idi's, and ive been searching around this forum for a bit so decided to make an account for stuff like this, so any help is appreciated!
