1978FrankenFord
How far south are you thewespaul? It makes a loud squeak noise when under heavy throttle and it makes a loud knock noise at idle. The oil drain will not allow the oil to go down through the valley pan. It either floods back up the whole or it makes its way back up through the turbo. Im going to start looking for another motor. Every bolt on part to make the motor run has be replaced so if its a good good block and heads ive got everything else. Thanks guys, im afraid this motor is shot from what you all have said
