Jesse248
Well my dual mass flywheel finally came apart. Anyone know of what single mass to replace if with or if its possible. Just dont like the dual mass flywheel.
As far as I know the only clutch kit you shouldn't use is one designed/balanced for the factory turbo engine. The above link is 93-94, makes me wonder if it's the turbo version. The flywheel is balanced differently than N/A stuff.Did you end up using a this kit? I am in the same situation with a 6.9, and from what I gather I'm not supposed to put a 7.3 idi flywheel on a 6.9 idi because of a balance differents. If you used this kit, do you notice any different vibrations after installation? The Luk kit doesn't come up on rock auto for a 1987 6.9, but does for a 1988 7.3 the only one for the 1987 6.9 was (BRUTE POWER/PERFECTION CLUTCH 91200SK). Any one use this conversion kit?
I just looked it up and those are the part #'s I bought as well. It's an EXCELLENT conversion!I used LuK LFW127 Flywheel and LuK 07-131 Clutch Set that were purchased from Amazon. Both are still working good
I was able to use my 6.9 flywheel and a pressure plate for a 6.9, and had clutchnet make me a friction disc with the 6.9 diameter and the larger ZF splines. You will need to lengthen the clutch pushrod 5/8” (.625”) to account for the thinner flywheel with the ZF clutchfork location.
Was that any cheaper than using a 7.3 conversion kit? I see rockauto has the complete kit including the flywheel for $250
