mac
At what temp should I plug it in? It's startin to get real cold at night.
And on the same note, when should I be adding anti-gelling additives?
Start plugging it in when you start having trouble starting it in the morning... or maybe when it dips below 45?
Do not worry about anti-gelling as long as you keep cycling fuel through the tanks regularly, the pump stations change to winter blends as it gets colder.
Maybe keep some kerosene or additive to mix in case you have a tank full of summer blend when it gets cold.
You could just plug it in all winter. It soooo much better for the motor to stay warm. Plus your heater works much faster
sticky situation... considering that the thing is huffing ether already, plug it in as often as you can
I have used the stock block heater on my truck, not any issues as of yet? Hahaha crossing my fingers i guess.
