So on my 6.9 I had to replace the factory mess that was the water separator. I'm putting a wix filter and base in instead and since I put a facet electric pump in I was wondering should I be putting the wix filter in before or after the facet pump? Does it even matter?
Also, my 6.9 gets the smallest amount of air in sitting uphill after a few days and since I've done all the return caps and lines and olives during my whole previous mess with this truck I think my air intrusion is that stupid return line from cylinder 1 that goes back up to the fuel filter. I have a single exit return cap I could use to eliminate it from there but how do I go about locating the steel fitting that comes out of the fuel filter housing that has that tiny nipple on the side for this return line to plug into?
