NW_Iron
Hi there, after looking at several different forums this seems to be the best IDI community. Been shopping, searching and doing a lot of research on Ford diesels after deciding to move on from my 2wd Dodge 400 BB. Started by looking at 460 Fords but have since moved onto diesels only.
My price range is in $5,000 neighborhood, I'm not expecting a prefect example but should be able to find a solid truck private party. Searching in the PNW has lead me to a few options from an n/a 6.9 up to a turbo 7.3l DI or PSD. I'll be using her for light duty construction runs, landscape duties, parts hauler, and occasional car hauler (missing out on too many opportunities on the other side of the passes). Don't need a daily driver but I don't want the 8mpg of my Dodge.
I'm mainly focused on the IDI's for their mechanical simplicity and track record of durability, along the same lines as a Cummins 12v, at least from my perspective.
So with that in mind is there much real difference between say a 7.3l with a 088 vs 093? I know the 093 is waste gated but with my once or twice a year haul over a pass it may nit matter much.
Would a first year 7.3l DI still be electronic? In which case I think I'll pass.
DIY turbo on a 6.9l with manual 4spd? This is my cheapest buy in at 20% the cost of other options, I could probably turbo it, cam and do head studs and gasket for less then the other options I'm looking at.
FYI these are all from examples I've either already driven or will this weekend/week.
Thanks
Thanks
