jonathan
does anyone make a 2wd to a 4wd conversion kit
Just need a good donor truck.
plus if it is the CC dually in his avatar, it will be a sweet rig in 4x4.
donor truck might be a gasser. or rolled, blown up, shot.
Corey,
Maybe its heresy here, but even a gasser could be a good truck.
I never drive off-road, so I'm no expert. But it seems to me that a long CC would be least likely to go off-road and need 4x. I note that you actually shortened up your "PlayRig". So I don't see that Jono's current truck would be much "sweeter" than it already is. Correct me if I'm wrong.
BTW, I gotta say that, from your photos, the off-roading looks hellafun. Where is the Rauch... place? And speaking of stacks, I see that you have a legitimate need.
Regards,
Still looking for someone to try my conversion idea. Take an IFS front end off an F-150 or Bronco. It will bolt right up. Use your existing coil springs. You can then upgrade the 1/2 ton front axle to 8 lug using the method I used on my Bronco.
only downside of that setup is the turning radius.i would love to have a CC, 4x4, 5 speed duallie. i would trade my dmax for it.
