hesutton
The Anti-Anderson
It is part of the trailer (or hauling) package option from Ford. I can't remember the actual Ford term for it now.
I plan on mounting it just above the rear storage compartment and running the wiring down under the camper. Gonna pull the skirt off the bottom. Likely bring it out through the propane tank closet and vent in the front.
The 12 pin plug on the F450 is on the bumper. Need to drop the plug for the camera/TPM out before the fifth wheel/bed of the truck. Would have been ideal to have both the 7 pin and 12 pin in the truck bed.... but they didn't do that.... just the 7 pin.
If it all works like it's supposed to.... should see what's behind the camper on my in cab monitor while backing her up. Usually not too bad at a campground. I have at least one spotter (Missy), usually more..... lots of "helpers" at most campgrounds. It will really help when putting it back into the shop at home and moving in crowded parking lots traveling to and from....
Heath
I plan on mounting it just above the rear storage compartment and running the wiring down under the camper. Gonna pull the skirt off the bottom. Likely bring it out through the propane tank closet and vent in the front. The 12 pin plug on the F450 is on the bumper. Need to drop the plug for the camera/TPM out before the fifth wheel/bed of the truck. Would have been ideal to have both the 7 pin and 12 pin in the truck bed.... but they didn't do that.... just the 7 pin.
Heath
at least it's a diesel.
