tknomaj
TowCat why are they messing with the gardners in Toyota PU's and f150 if the comercial limit is 14000lbs not to argue but currosity killed the Cat
that's local DOT stuff. DOT is DOT, they govern the operational safety of commercial vehicles. the 14k rule going into effect is to put into obsolescence diesels older than model year 2004. if you own a truck in that weight class, you have three choices.TowCat why are they messing with the gardners in Toyota PU's and f150 if the comercial limit is 14000lbs not to argue but currosity killed the Cat
nope.If I paint it like this they will leave me alone.
I would still like to get that VC if you have it.
I knew what you were getting at, but the reality was very different.I was trying to be funny. I guess it didn't work.![]()
OK, you guys convinced me into looking at using the PS. Any suggestions on how to run the plumbing on the motor?
it was a general joke that public agencies were going to get an exemption because they can. nope. not this time. alot of taxpayer monies are being burned to get the new stuff.
I ran 75% wmo in my primary driver for 2 years, and I do a lot of driving. I do multi-state also, but not every day. I did no special plumbing and never replaced any hard parts, except fuel filter every 6-8k miles. Never so much as hard started on wmo, I have had no regrets using what so ever. I have saved enough cash using it to buy several engines at this point. Money saved is money earned in my book, and I have saved thousands on fuel running wmo. I only filter to 10 microns also, which is a bit to bog for some, but I don't have issues with it. I think you will find wmo a lot more plentiful then wvo. That is unless you have a unlimited source. The guys around here hoard it.
You have separate tanks. Is it a factory setup?
No seperate tanks, goes right on the regular fuel tank. I basically just treat it like regular old #2. really it's good old #4 though.![]()
No heat? You asked about heat before. Now you say you run it like regular diesel? I wouldn't do that with veg oil, why would I with WMO?
yes it can be done...but with a really big BUT......
first, you will be violating all sorts of smog laws.
second. your life will be greatly simplified if you choose a turbo system set up for a ford IDI.
third, you will be the first in doing the IDI to Ex swap. good luck![]()
