1990 f250 idi value
Law2212
Ohio
Alright guys i have a 1990 f250 supercab that i have been building, but i am running into problem of having to many projects. (Own 14 vehicles)
So truck is a 1990 f250 supercab 7.3 idi. Truck was originally 2wd but i converted it to a straight axle 4wd, with a sm465 manual transmission. Transmission has aluminum bellhousing all new flywheel and hydraulic clutch, backed with a bw1345 transfer case and a gear vendors overdrive unit on back of transfer case.
Truck has a sterling rear end, with a dana 50hd front axle with dana 60 hub assemblies. Truck has 4 or 6 i inches of lift (cant remember lol) full leaf in front, block in rear. Have a set of 37's hummer tires for it.
Truck has gooseneck hitch in bed, factory ac works perfectly, power windows, power door locks. Front clip was converted to a bullnose. Body and bed are solid and rust free. Interior isn't perfect but its not bad.
I am sure i am missing a few things, but thats most of it. I was just wondering if you had any ideas of what it would be worth.
There are 2 different trucks in pictures white is my 86 f250 (36 inch tires) that i pulled lift off of and nose. Black is the diesel before i started conversion.
pictures as it sits atm.
Law2212
Ohio
Pictures
genscripter
Inglewood, CA
So truck is a 1990 f250 supercab 7.3 idi (non-turbo, $500). Truck was originally 2wd but i converted it to a straight axle 4wd, +$1000 with a sm465 manual transmission. +$300 Transmission has aluminum bellhousing all new flywheel and hydraulic clutch, +$300 backed with a bw1345 transfer case and a gear vendors overdrive unit +$500 on back of transfer case.
Truck has a sterling rear end, with a dana 50hd front axle with dana 60 hub assemblies. Truck has 4 or 6 i inches of lift (cant remember lol) full leaf in front, block in rear. Have a set of 37's hummer tires +$500 for it.
Truck has gooseneck hitch in bed, factory ac works perfectly +$200, power windows, power door locks. Front clip was converted to a bullnose. Body and bed are solid and rust free (+$0 in the southwest, or +$900 in rustbelt). Interior isn't perfect but its not bad (-$400 if the buyer has a wife, or +$0 if a single man).
That puts it around $2800 in the southwest on the low end, and about $4100 on the high end. that's still too high for my tastes, but you should be able to find a buyer at those valuations.
If you parted out the truck, you could make more money. Just that GVOD alone could get you over $1000 on ebay.
Law2212
Ohio
Stock fuel system and motor, 188,000 miles, new glow plugs and controller. Runs great, no issues.
Lance
Staff online
