1984 F250 tank upgrades
Glsawyer
Aberdeen,wa
I'd bet that if you were to get a tank and sending unitfor a Bronco with EFI, it would. They also need to have a return line since the electric fuel pump is always pumping a large volume of gasoline.
what year will work?
nj_m715
government's finest
NE of Atlanta
I used a mogas sender from the same year make/model and made it work. as long as it's the right size for the tank, you're good
ebay has plenty of them pretty cheap, since we have to mod the sender to fit the large tank it wasn't extra work.
I had to snip a new notch for the tabs to properly clock the sender in the tank
catbird7
PA
I think this one works for just about all Bull, Brick, & OBS. "Please return your tray to the upright position and remain in a seated position before looking up price"!
Glsawyer
Aberdeen,wa
so im thinking im goin to use the sender i have. if i do i plan to have a fitting soldered into the tank for a return line. i also an thinking i will remove the vent tube from the filler and have a 1/2inch fitting soldered into the tank to run as a new vent line with a filter. then i can will tank quickly without it shutting the pump off every half gallon. i plan to use the universal selector valve as i found a diagram on how to wire it in.
From what I recall, the bull and bricks used a different wiring plug on the FSV. I don't think this one is that universal.
nj_m715
government's finest
NE of Atlanta
turn your roll over valve into a vent
drill a hole and solder a steel line to fab a return
Glsawyer
Aberdeen,wa
had to jb weld it but it is in. 1/2inch id vent running up by filler neck. vent in filler removed. it was collapsed. extened the sending unit. so tomorrow ill see if it all workes
Knuckledragger
Payson, AZ
I am late to the party, but why not solder the return into the sender, like the stock ones have?
Glsawyer
Aberdeen,wa
i placed it about an inch higher on the tank.
new problem...removed front tank. lines and selector valve. new pumpo is about 2ft from rear tank....on frame rail. i repaced the last on when i did the tank install. even thought it was only 3days old. keeps running dry at the filter on motor...then i have to stop and bleed the system when it dies. after about a mile
Glsawyer
Aberdeen,wa
my guese is air intrusion from a second leaking injector? plus a couple return lines are leaking...basically the whole passenger side of motor
Glsawyer
Aberdeen,wa
go home and pulled the injectors from my 7.3 ive got as a spare...great shape..bb code. got new line and real fuel injection clamps for the return system. also going to remove the return line going to filter head. all that should stop the air getting in
Glsawyer
Aberdeen,wa
injectors are in. new hoses are on. only 1 leak from #4 injector..very small but drove it and now it dosent bubble. so assume it just had to get seated better. was able to drive a few miles, i even drove barefoot so i could feel the motor better. little loppy at idle but smoth under power
lewisstevey7
