Dsl_Dog_Treat
I have some kerosene, and I was wondering if a 50/50 mix of kerosene and engine oil would be ok?
Yup, just got thru a 5 gal kero and a 6 gal WMO mix. Did purdy good I might say.
it's not a good thing. those deposits are forming all over on the inside of your combustion area and on the backsides of your valves. I've seen some pretty heavy deposits in the past on the valves on the two rear cylinders (cdr issues) but when you're running straight WMO it's happening in all 8 now.If you pull the plugs you will see White ash on the tips. mine was built up pretty good, enough that I scraped some off pulling the plug out. I cant say if this is a good or bad thing.
.....Damn near the price of milk.....Might be a good business opportunity to collect WMO and re-sell it as clean diesel fuel....I know around here they pay 7-8 cents per litre for it and then after they filter it they sell it for 35-40 cents per litre as bulk oil for waste oil furnaces.it's not a good thing. those deposits are forming all over on the inside of your combustion area and on the backsides of your valves. I've seen some pretty heavy deposits in the past on the valves on the two rear cylinders (cdr issues) but when you're running straight WMO it's happening in all 8 now.
i had a hell of a time bleading the air out the other day bcause of it. time to drop it and inspect i guess.What are you using to filter the oil?
i am using a goldenrod 10 mic filter then a 1 mic house filter. you can pick it all up at tractor supply. i am looking into what it would take to make or buy a centerfuge then i could filter down to 1/10 of a mic and never have to worry about buying filters again.
buy a centerfuge where at? I saw one some where that drop at the door was $17k![]()
