01 F350 runs bad
Ironman03R
Risingsun, OH (NW OH)
I thought it was odd too, then they all ohmed out good. I didnt see any wire chafing either. I'll try wiggleing the plugs around and see what happens.
Ironman03R
Seems to be fixed! Changed #6 injector and installed TSB part # 2C3Z-14A163-AB retainer clip to UVCH.
What are labor times for replacing GP's, R/R 1 injector and R/R turbo compressor housing?
I did all that, serviced the transmission, and fixed the auto hub vacuum leak, I'm figuring about 8 hours labor... Sound about right?
BigRigTech
Diesel junky
Nova Scotia, Canada
8hrs seems reasonable, sounds like a days work to me.;Sweet...Faults for both opens and shorts can be commom, we see this a lot on the 60 series Detroits....Oil seeps down inside casing on the injector wiring and shorts stuff out....It's wierd but it happens...I replaced an injection harness for this reason yesterday...I had oil inside the harness plug that hooks to the ECM and it's outside the valve cover about a foot away.:eek::rolleyes:
RangerDanger
