00really Cheap Ebay Turbo
flatlander
plays dirty when losing
ft. wayne IN
Look close, it's an exhaust manifold only for $109. You'd need 2. You'd also need 2 turbos. Plus lots of plumbing. I love the description of the horsepower gains.
tractorman86
Buckeye, AZ
well im with u flatlander! "exceptional horse power gains":rotflmao !!! could be a good start for an idea for a twin turbo setup but there are several problems. the turbo is on the front of the manifold(manifold is designed to flow towards back) which cant be a good design, u'd spend 218 just on the manifolds that someone made in their shed from some scrap metal(will probably crack and go to hell the first time u stomped on it in a hard pull) :eek: , and like mentioned above u'd have to spend big $$$ to get ahold of all the plumbing, and u'd spend even bigger $$$ to get two matching turbos which he dosnt even give any des. on :puke: (make,model or even just dimentions of the bolt pattern)!!! this is about wat he is doing to who ever buys this--> :kick: :rotflmao
Exekiel69
Got to be carefull with them sellers, they got Me but for much less money one time. The description make you think you get the turbocharger along with the manifold. Have to read it all with this suckers.
Mr_Roboto
Elyria, near Cleveland Ohio
I believe this is intended to be a single turbo setuo. Notice how the original end of the manifold is still there. You would run a crossover pipe from your right manifold, and exhaust would flow from the right manifold, through the crossover pipe, into the left manifold, and through the turbo.
EvergreenRanch
In Transition
SF Bay Area, CA
seems to me that the turbo would be in conflict (or at least the plumbing of it) with the steering box? anyone else think the welding job looks hack? unless thats a quadruple pass of some technique ive never encountered (unlikely) it looks pretty ***** to me.
sle2115
NRA LIFE MEMBER
Southeast Ohio
Yep, I wasn't real impressed with the welding either.
typ4
Newberg,OR
Someones got a real sense of humor, where is the exhaust going to run, out the hood? Maybe stick it out the fender :rotflmao
F350camper
BOOST!
USA
Yup, thats the only way it could work.
Looks like standard square tubing welded to cast iron to me. I do tig welding with inconel 347 and just about any kind of stainless in the 300 or 400 series at work but have not done this kind of "stuff". It will not hold. When cast iron heats up it expands much differantly than mild steel so you know what happens next. I know of one shop on the east coast that can really weld cast iron and they don't give calsses in it. They welded 2, 350 chevy blocks together and made a monster motor. Other than that I can't see this mess working but hey. Its somebody trying..... :rotflmao
krawlr
Yup, that's me
Cincinnati, OH
A 6" stack out the hood would be sooo cool! Right in front of the driver. :rotflmao
82fordtruck
NE Kansas
This was my concern as well. I agree with mr-roboto as far as plumbing, that would be the only way to make it work.
dented73
