ah1988ford
have a question should I use the 2 gaskets for the timing cover or just use RTV? Or a combination of both? I did not use the gasket for the rear main I just used RTV and did not have any issues
This is a personal choice I suppose....most often its about surface prep more than this or that product.have a question should I use the 2 gaskets for the timing cover or just use RTV? Or a combination of both? I did not use the gasket for the rear main I just used RTV and did not have any issues
X 2!Combo.... I never trust sealer alone. Very light coat of it on both sides of the gaskets, let it tack up a few minutes assemble and wait till it cures before doing anything with it...
