My Eco is in the need of a new starter motor and flywheel.
Which Starter Motor should be chosen?
BBB INDUSTRIES N16658
or
BBB INDUSTRIES N17037
or what do you suggest?
What pops up when browsing over the specs, then I can see different power ratings.
Why are they available/necessary for our motor?
How to choose the (right) one our engine needs?
We all know: consumption is not output power
As the Eco is driving with WVO (and I have a mechanical lift pump), often I am in the need of some extra power (I have 2 red Optima's + 1 x 180AH as "backup/support").
I had the Mitsubishi starters running for some year. In January I installed something that looks like a BBB INDUSTRIES N16658
But back then I did not replace the flywheel. Now I have to replace both, because the old flywheel is now broken and I suppose that the gear on the new motor isn't new anymore
Oh yeah: What about new bolts? When looking @ this:
Then maybe I should get them too before the transmission is on the ground. Would RA have them?
Sorry for linking Rockauto - even they are not supporting the forum (for the moment).
or
7.3 flywheel bolt snapped on install, NAPA and RockAuto list different bolt
Nasty surprise bolting on the flywheel. The first bolt we tried to torque, at 30 ftlbs, stretched then broke. NAPA doesn't have any in stock. Has anybody had this kind of issue? The remaining 8 flywheel bolts sound like hardened steel when dropped on concrete. They ring. The one that broke...
www.oilburners.net
