ZF6 same pattern as ZF5
Diesel_brad
Dunce
gilbert pa
For all the nay sayers out there. Here is the proof. On the left is my ZF6 out out my 99 f550 w a powerstroke. On the left is a ZF5 out of an IDI
Once the other photos load, i will show you the tin plate from the ZF6 on the ZF5 showing they are the SAME pattern
GOOSE
Happy IDI'er
Galloway Twp, NJ, USA
Very nice Brad;Sweet What a cool swap that would be. That and the newer T-cases surely would be overkill for our rigs.LOL
Diesel_brad
Dunce
gilbert pa
This is the ZF6 with the thin tin plate(about 1/8")
This is the ZF5 with the ZF6 plate
If you notice. They are the SAME patten. The zf6 does not use an adapter plate like the ZF5 does on an IDI, so I will assume you just use the IDI adapter plate and bolt the ZF6 on
Diesel_brad
Dunce
gilbert pa
And F'n EXPENSIVE
A ZF6 typically sells for 1000-1500. And a t-case to go with it is around 500 for a used one
That ZF5sp is just not going to work...it's missing an input shaft and other stuff from the looks of things:eek: Just thought you should know before you attempt installing it:rotflmao
Its the ultra light duty version.
Diesel_brad
Dunce
gilbert pa
Ya I can imagine.....if it was a IRON case? :eek::rotflmao
Whats the scoop on that thar 5sp case? can a gasser gearset be stuffed in that really easy?:rolleyes::rotflmao
The zf6 is a aluminum case
As for the zf5. I am just holding on to the case, just in case I ever need one. And yes a gasser guts can be put in it
trapper
Boom Boom
Chatsworth Georgia
First of all, you have to remove the approximately 1" thick adapter plate the IDI's use in order to get the clutch and flywheel spacing correct. In other words, the bellhousing on the ZF6 is deeper and the input shaft is shorter, so the spacer has to go.
Diesel_brad
Dunce
gilbert pa
I think you are wrong
lewisstevey7
