rhkcommander
Sorry was thinking zf 460 not t19
Try find a NP435 then...or T18...just sayingWhen I did my t-19 swap, I used a 460 trans, and there was not enough room to mod the gas bell to fit the diesel.
The low gear is awsome, I dont know *** they were thinking with that stupid 4:1 first.
THe gear splits actually work out pretty good (better than the diesel version imo) and the only time I notice the gap between 3 and 4 is if I try to down shift on a big hill to early.
The next t-19 diesel truck I have I will search for the low gear t19 and replace that stupid 4:1 first gear trans.
FWIW when my T-19 came out, the first thing I did was set it next to the ZF that I was about to install, on a work bench. With both transmissions sitting vertically, with the bell housing to engine mating surface down on the bench, I measured them both. It turned out that, in my case, they were identical in length....from the bellhousing mating surface to the transfer case mating surface (including the tail piece on the T-19), they were both exactly 26 3/4" long. A pleasant surprise for me; I was expecting to need to resize driveshafts, but that ended up not being necessary...I ended up not needing to modify the driveshafts at all It's worth noting that I kept the original 13-45 transfer case; there may be a difference in length between the 13-45 and the 13-56.to swap a T19 you will likely need new driveshafts as the transmission is SHORTER...thus shorter front shaft and longer rear. Also may need another cross member.
YMMV, but I found that 3rd-4th split on the T-19 to be maddening! With 4.10's, I'd have the engine pretty well wound up in 3rd by 35 mph or so, and upshifting to 4th brought the RPM's too low. Almost as much as gaining that 5th gear for the highway, getting the closer split between 3rd and 4th was a great benefit from swapping to the ZF...The low gear is awsome, I dont know *** they were thinking with that stupid 4:1 first.
