Would you trust your engine on a HF stand?
homelessduck
The only stand I have is a 1,000lb HF stand. The heads are off, and it is just the bottom end. I need to flip it, and have no other way.. What do you guys think?
My first thoughts are nope but.... If you are not going to add the heads then I feel you will be safe. Just expect the unexpected around this questionable engine stand.
homelessduck
I thought it SHOULD hold it without the heads, but, it IS from HF.:rolleyes: It's either risk the stand dropping it, and being relatively safe, or tossing it on the lift, and crawling under it. :eek::eek:
block w/o heads...no problem.
fully assembled motor....really really really bad idea.
even with the OTC monster I own, I get a fair amount of bounce in the stand.
homelessduck
When it comes down to it, I would rather drop the block than die.;Sweet And I don't really have the cash for a huge stand, so... I guess I will try it. You guys made me feel more comfortable doing it.:D
Dsl_Dog_Treat
Decatur,MI
I've got that same stand and wouldn't trust anything heavier than a bare bones 460.
Waaaaay too much forward lean and my scrawny ass couldn't rotate the motor if my life depended upon it.
Only reason I have it is because it was given to me, brand new never been used........................Still.:rolleyes:
BrandonMag
Dana 50 rebuilder
Oregon east
homelessduck
I just set it on the stand... It seems to be holding it, without much sag. Trying to rotate it upside down was WAY too sketchy. I guess I will just have to use the stand as added " safety " and crawl under it.. with the hoist still attached as well. :rolleyes:
93f250idi
strokin
cadiz ky
I've got the same stand and it sags like hell with a 4 cyl c farmall tractor engine. Maybe I got a defective one :D
jperecko
Diesel Ape
Boonies of SoCal
I put a complete engine on the red HF 2k? stand and it took it well but still had a good amount of flex when the load was applied. When using HF load bearing stuff, I like to half their rated capacity for a little extra FOS.
6.9poweredscout
Bleeds IH red...
Northeastern Pa
http://www.harborfreight.com/2000-lb-capacity-engine-stand-4420.html
i have that one, it held my assembeled 6.9 with MINIMAL tipping, it knew it was there but wasn't about to drop it. i had to ream the one mount to fit the 6.9 but it worked. if i was away, or over night i put a 4x4 block under the crank just incase. i had to grease the hell out of the shaft so i could rotate it, that was an effort but it'd turn!cookoo wish they put bearings in them! oh and keep an eye out for specials, i think i got mine for like $89!
-Jon
