would like opinions on welding the DMF
65sixbanger
New Braunfels, Texas
If you have the flywheel out, you can actually take apart the DMF and remove the springs and little clutch device it has in there. i had to do this when a pressure plate bolt broke off in there. If I had known I was going to weld it I would have gutted it and welded it on the table instead of upside down.
pacaman
Amelia, Va
I know some guys have sucessfully done it. In theory, if you make a bunch of small welds evenly spaced around you might make out OK. However, a lot of this depends on your skill as a welder. If you do the Lucky Mod, the skill required is much less. Also, if you opt to weld it, you really should gut it first, like you would with a lucky mod, or there may be noises from the loose and broken parts inside.
OK I have to ask. What is the "Lucky mod"? I am planning a clutch replacment this fall/ winter and was looking into a single mass fly wheel upgrade. I'm reading the forumns prior to the job and I see the term but haven't found the description.
Also; Should I plan on replacing the rear main while I have the fly wheel off?
Thanks in advance for the help.
PS: my last winter project was a Moose pump and "WOW" wish I'd done it sooner. Thanks Mel
94turboidi
Ne So. Dakota
I am going over to pick mine up from the shop. I had it welded. They are a very professional shop the downside is that it has taken them 3-4 weeks to get around to it. They said they were going to preheat it a little bit before welding. I will take some pics of it when I get back home. They told me 20.00 to weld it. I think it would have taken me that much to buy a decent drill bit and bolts plus the frustration of not having a drill press. If it gives me any problem I will just switch the whole flywheel out later.
TWeatherford
Flagstaff, AZ
My welder has a $40 setup fee. I'm sure getting him to drag his beer belly under the truck would be $60. Hope your flywheel does well for ya. Is your clutch sprung? Please let us know how it lasts.
94turboidi
Ne So. Dakota
Here it is. It looks like it will hold up fine. I guess I will find out. I left it all together before he welded it because I didn't want to mess anything up. I am going to try to cut out the springs with a angle grinder by cutting in a few places and pulling the pieces out so nothing is rattling around. I am sure it won't be completely balanced. I had him weld right where the pressure plate bolts to in six places.
94turboidi
Ne So. Dakota
SACHS Part # K006502 is the clutch kit I am ordering. It is 164.89 on Rockauto and yes it has springs in it. I am getting a few gaskets at the same time and they gave me a 5 percent discount code that they said anyone can use so if someone wants it let me know. I will be sure to let you know how it works out. It might be a few weeks before the truck is back together but if it is a bunch of crap I will let you all know so you don't waste your time. I think it will be fine though. They ended up only charging me 15 to weld it.
RLDSL
Diesel fuel abuser
Arkansas
Nice looking job. THey welded it with good penetration and have roughly 2-3 times teh surface contact area of the bolts holding the pressure plate on. If it balances out, I don't see why it would have any trouble. I don't know if they balanced it, but a simple tire bubble balancer would tell you, and I imagine you could atach those stick on wheel weights on teh backside to balance it.
94turboidi
Ne So. Dakota
Yeah you can tell it was a hotter weld its not all smooth and pretty but it penetrates good. Ok that sounds bad but anyways if it all works out I will have about 180.00 into a "SMF" conversion.
91idi
Fiberglass *****
X
or grind a little if its pretty close. If one of the weights came off it could get interrestin':eek:
sassyrel
iowa
good idea--but nuh huh--toooo many rpms!!! wayyyyy faster than a tire--but any good machine shop could balance it--if they do engine balancing
phazertwo
Die Summer DIE!
Crawlorado!
If it balances out, and IF its not soft as a
from being annealed from the heat of welding.
I will be interested to see how this turns out!
:popcorn
PZ
Edit: I would imagine that it would be hard to find a shop to resurface any modded flywheel, something to consider before putting money into modding it.
